Hi All,
I would like to flash lights in a specific order when there is a fire alarm in the house. With Hue I can select Flash short/long and repeat this easily. So I can create: Flash Hue light 1 long → 2 sec. delay → flash Hue light 2 long,… and then repeat the flow (so they flash in that order, till fire alarm is off).
But I have also Innr lights in my house, that are not connected to Hue bridge, but directly to Homey and the app (Innr) doesn’t support flashing yet.
Is there a way, except turning on and switching off the lights in flows and repeat this, to make this possible?
I don’t know if this is possible with Homeyscript, to set a script that they need to flash (in specific order) when smoke alarm X turned on, (till smoke alarm is off). I don’t have the coding skills yet to create this, if this is even possible.
If this is possible: This is then 1 script to flash a specific light, that you can enter for 1 light, or what is the best then?
I have the Advanced Flow possibility and I like to set this up in an Advanced flow.
Thanks for the info, tips and the help!
