I have an idea of a flow. I have a lot of philips Hue bulbs.
I an party setting, I would like the lights to be “running”, on and of in a sequal. After a time, (when the music stops), all lights turn off, and then a random light turn on. The person under the light, have to… etc. Like spin the bottle.
Anyone up for the task? Im a newbee, but the sequence, music I can do. But the random I dont know how to.
Funny Idea, how you want to play the Music? Alexa? I ask because you are dependent from the available flow cards for crating the advanced flows…and how i can imagine the end phase when a light shine to a person…every person is seated under a bulb ???
Hi, thanks for the respond. Yes, I have 10 GU10 Spots on a cealing rack. To start each game I was planning to use Fibaro the Button. Music plays from Sonos with spotify.
That being said… you cannot really create a true “disco” experience with it, especially if you have a lot of lights. Zigbee is simply too slow to change multiple lights at once or cycle through colors quickly.
Before I had Hue lights, I used those cheap Mi-Light bulbs (which I had to abandon because Athom refused to update their app to SDK v3 at the time). Those had a built-in “disco” mode, and activating that worked way better.
So, sorry to say, Zigbee is just not up to the task. Even the official Philips Hue Disco integration limits it to around 10 lights max (or something around that number).
The flow starts with a button-click and turns on 10 lights and starts a transition.
This transition does 9 steps in 9 seconds. So every second a random light is turned off. Leaving only 1 light on.
If a light is already turned off the flow restarts itself from the start-button.
