Due to the fact that both statusses are not working anymore, my flows to ring via external bell do not work anymore. It used to work for a long time.
Auhentication is OK.
Camera view in Homey is also OK.
What can I do to restore status doorbell as selectable.
Because both statuses have stopped working, my flows to ring the external bell no longer function. This used to work for a long time.
Authentication is OK.
The camera view in Homey is also OK.
What can I do to restore the doorbell status so that it becomes selectable again?
Have you tried restarting the Ring app in More->Apps->Ring->Settings (top right corner)?
Opnieuw opstarten, geeft geen verbetering.
App verwijderen en opnieuw installeren geeft slechts 1x een melding en daarna niets meer.
Livebeeld van de deurbelcamera wordt juist weergegeven, dus er zijn de juiste verbindingen tussen Homey en Ring..
Rebooting does not improve anything.
Uninstalling and reinstalling the app only produces one notification initially, after which nothing appears anymore.
The live feed from the doorbell camera displays correctly, so the connections between Homey and Ring appear to be properly established.
