Ring Security - Extend Heimdall with Ring Security products
One thing to check first is if there is apps for Homey that includes all your devices.
See Apps for Homey Pro and search for “Ring” and “Netatmo”.
It might be that the Heimdall will not recognize some of the sensors directly, meaning you will have to create flows to trigger a virtual devices.
Heimdall will be your alarm system but the “only” thing it does is to let you set alarm state and trigger flows when a sensor is triggered.
Thanks Anders.
Yes, I find Ring, Hue and Netatmo in the App Store.
It seems that what I would like to do might work globally.
However I would like to be aware of the limitations before to spend such an amount of money in the Homey pro.
Also I dont find how I can control my Devialet Speaker or how I can play a Siren sound on them.
If you click on a device in the app store you will see what you may do with it.
E.g Ring siren is not supported.
As far as I know you will not be able to trigger anything from Homey to the Ring alarm system, only use (some) of the devices.
Devialet Phantom seems not supported, Google speakers should be. Search for your speakers in this forum in all topics and you might find answers.
Just quick follow-up @DaneedeKruyff .
I removed all Z-Wave devices. I did reset my Z-Wave. Only linked the keypad. Did not work. I can pair, I can send updates to the keypad, but not receiving anything.
I bought the new Homey Pro. Installed Ring Security via the iOS App. Clean install, no migration. Homey pairing fails with wrong pin. Pairing with “old” homey did work shortly after :thinking:
I did then migrate my old homey to the new homey. Homey advised to shutdown the old Homey to avoid conflicts.
Just before I wanted to jump to the store to get the Ring Keypad reviewed, I wanted to give it a final test and… it started to work.
So, clueless why it started to work. Only real thing I see is that the old Homey is offline :man_shrugging:
The Heimdall app is great, thanks for all the work, and support here :bowing_man: .
oh… Thanks for this.
It’s a pity that Ring security is so limited. Interaction could be so valuable with other domotic appliances.
Then I know that Homey is not what will help me on this :roll_eyes:
Its a bit frustrated while they claim its “THE” hub open to all kind of system.
But its better to be advised upfront concerning my specific need.
Thanks again !
If you had both Homey’s running they would interfere, both trying to talk to the keypad. This probably caused your problem.
One other thing I noticed is that it might take a reboot of the Homey after you have included the keypad.
Why do you not move to Homey as your alarm system, and stop using the Ring alarm controller?
You can still use all sensors and a new siren is cheap.
I only bought the new homey after all the keypad issues (Black Friday deal with local vendor). I had them shortly running at the same time shortly (the new homey as factory clean), where the keypad could pair with the old, but failed to pair with the new one. I would not expect interference with unlinked devices? Keypad was always unlinked from the homey before I tried to add them. It’s really weird thing, as it hardly fails on the old homey for ages now :man_shrugging:
I really can not explain why it is working now, but I’m happy for you it is!
Perhaps resetting it to get it connected to Homey Pro 2023 did the trick, but your guess is as good as mine. Anyway, glad it’s working, have fun with it!
I have this exact issue after migrating to my new Homey Pro… But my old homey is already switched off…
Really not looking forward to resetting my entire z-wave network…
Any other clues before I embark on that journey…?
Have you tried rebooting the Homey?
My Ring keypad only worked occasionally, but after rebooting the Homey it works as a charm.
Well… I don’t have much of a choice anymore… After adding the keypad and rebooting the Homey pro the keypad was indeed working again…
But unfortunately all other z-wave devices had vanished. Floor heating pump switches, a dozen motion sensors, another dozen contact sensors. All gone. Great. Will be spending hours climbing ladders and resetting them… Absolute sh. Show.
Started re-adding devices and at least they’re staying after a reboot, but this transition has been way too painful
Please report this to Athom, the chance they are reading along in this topic is slim to none. Your information may help them to improve a future release and help other users and not just of this app.
Dear Daneede, I’m trying unsuccessfully to add a keypad ring v1 to my homey and this post here talks about the regions. Could you add these codes for the keypad ring version 1 for US/CA?
Manufacturer ID 838
Product Type ID 257
Product ID 513
Thanks
Hello, there’s really something I don’t understand. I’ve had the Homey 2023 keyboard since October, and from time to time, it doesn’t activate or deactivate the alarm. A red network symbol flashes when a key is pressed, and after several hours, it starts working again. This morning, I activated the alarm without any issues, but an hour later, I couldn’t deactivate it. This has happened several times in the past 3 months. All my other Z-Wave devices don’t have any disconnection issues. I would really like to know the cause. I believe an update should be planned to address this problem. My box doesn’t disconnect because I have a flow that notifies me when the network goes down, so the issue doesn’t come from that.
I also have issues with the Ring keypad. It works occasionally.
My solution was to restart the Ring app at every surveillance mode change (arm/disarm), and since that it works flawless.
I have not enabled the Heimdall integration, need to arm/disarm using flows for different reasons.
But with Heimdall integration it also was unstable.
Are you restarting the application manually each time, or using a flow?
Using a flow.
I didn’t know that we could restart an app through the flow. I will look into it tonight and add it to see if the keyboard behaves better.
Can you give me an example of an advanced flow? I can’t figure out how to restart the Ring application.
