Ring Doorbell, Camera and Alarm support for Homey
As a follow up to the previous post announcing the introduction of support for the Ring Alarm system which started with the addition of the Ring Contact Sensor.
Here’s what device to add:
If this is the first device you’re adding you’ll have to authorise at Ring, make sure to have your logon information available, otherwise the regular device add wizard is run.
After adding the device you can make your first flow with it, these are the flow cards available for the Ring Contact Sensor:
The motion reset timer is a fixed value which is set by Ring and can not be changed in the device.
