[Request] Slider for Curtains
I am using matter based curtain motor, recently i replaced my room setup with poe screens using dashboard, the setup lacks slider option the same which is used in moods option in dashboard.
Did you try the Enhanced Device Widget app. Maybe this will give you a slider for your curtains.
Yes, I do use this feature, but unfortunately, the slider is not accurate and does not work as expected.
Sometimes, when I try to drag it, it gets stuck at a certain percentage that I don’t want. However, if I tap on a specific position, it moves directly to that point. In this way, I don’t think it functions as a true slider.
I have that too, its annoying when you want to adjust a sound volume level from 20% to 25%, but instead it flies to 80% with massive volume.
i did also make a curtain slider with the app mentiond above, but does anyone now if there is a option to make 2 sliders at one bar?
on coming form the left coing to the richt for the left curtain and the other coming from the left in going to the right?
now i have 2 widget’s for one pair of curtains.
