Just posting here in case others are also facing the same or similar issue: I was looking for a proper solution to set the speed of an array of four 12 VDC fans. Oddly, there are no Zigbee controllers available specifically for that purpose! My utility cupboard is home for one of my Marstek Venus E 3.0 batteries, a UPC, my home fuse box (3 x 25A), four NAS devices, my FTU, router and switch so it can get a tad warm in there.
So I purchased a Gledopto GL-C-009P led dimmer (non RGB, single channel) and set that up as the controller. Works like a charm, so a small advanced flow now controls the speed of these fans based on the measured temperature (as provided by a Zigbee eWeLink temp / humidity sensor). Downside is that the fans now hum quite loud because of the way the Gledopto cuts the voltage (duty cycle of 3 kHz). However, with an added LC filter it’s now virtually soundless.
Fan array used:
Gledopto purchased here:
LC filter from China or thereabout:
And finally, the sensor:
Hope it helps anyone!
