Rainpoint
Good morning,
does anyone use RainPoint products?
I wanted to know if someone had integrated it into homey, if so how?
And if someone would have an application development in sight, knowing that it is Tuya compatible?
thank you for your answers
It seems Tuya Wifi compatible indeed.
Howto Tuya:
With so called tap-to-run scenes, and/or RAW Commands you can control anything whithout needing direct device support.
It’s all mentioned and explained in the Tuya howto above.
ok thanks i will look into that
IT’s good thanks a lot
Hi, Did you manage to get Rainpoint working with Homey Pro? I am curious since I want to incorporate them into Homey.
Hello, yes via tuya cloud, it works perfectly.
If you need help, don’t worry
Thanks, Could you please give more details on how it was added? Is it via tuya cloud - socket? Do I need to keep Immax Neo application active?
Good morning,
you must first integrate them into tuya.
Create an ON and OFF scene and an OFF scene in Tuya :
Then install Tuya Cloud on HomeyPro :
Create a virtual button on HomeyPro with Virtual Device :
Then for each scene in Tuya create a scene in HomeyPRo :
Then you can integrate it into any flow in homey :grin:
There you go, I don’t know if this is the best solution but it’s mine and it works.
Thanks; it helped me a lot. The only thing which took me an hour and it was the registration of Tuya Cloud [App][Pro] Tuya Cloud in https://iot.tuya.com/ .
Hi everyone,
sorry but it’s not clear to me how to switch devices from the RainPoint app to the Tuya app.
Thanks everyone
Rainpoint
Tuya
