Raining alert once in 30 minutes
Which water sensor are u using as a rain detector?
I’m curios as I’ve not had luck with one that works well without draining the battery fast…
Create a better logic variable,
name it notification or something. Either a boolean or number,
then set the variable to true or as the example below, i increment it 1 time. And the flow will stop once it notify me twice that the ziptrak is closed.
You then need to create another flow to reset the better logic variable when u open the ziptrak for e.g…
Or in your case, every 30mins, set variable to 0 or false…
