Quick memo to get Alexa see Homey flows as scenes
:clipboard: QUICK MEMO โ€” Syncing Homey with Alexa Without Chaos
:bullseye: Goal:
Make Homey flows appear as scenes in Alexa, while avoiding duplicated devices and broken routines.
:purple_circle: 0. Rename devices in Homey with a prefix (e.g. โ€œH_โ€, โ€œTEMP_โ€)
Helps quickly identify Homey-sourced devices in Alexa after detection.
:purple_circle: 1. Create a Homey flow that can be detected as a scene
  • :white_check_mark: Mark the flow as a favorite (star icon enabled)
  • :white_check_mark: Give it a clear and simple name (e.g. โ€œTurn on displayโ€)
  • :cross_mark: Avoid complex conditions or triggers that Alexa canโ€™t interpret
  • :warning: Avoid creating virtual devices unless absolutely needed to make the flow visible
:yellow_circle: 2. Trigger detection in Alexa
  • Open Alexa > Skills > Philips Hue > Settings*
  • This triggers a full scan of connected systems
    *(Works with other skills too, not just Hue)
  • :white_check_mark: Alexa picks up Homey flows as scenes
  • :cross_mark: But also discovers all exposed Homey devices, leading to duplicates
:red_circle: 3. Handling duplicated devices
  • :eyes: Newly detected devices are marked โ€œNewโ€ (green dot)
  • :warning: Alexa treats these as separate entities, which breaks existing routines
  • :soap: Solution:
  • Manually remove the newly detected Homey devices (thanks to the prefix)
  • Keep the original versions to ensure routines continue to work properly
:broom: 4. Optimized manual cleanup
  • Create a group in Alexa called โ€œTo Deleteโ€
  • Add all duplicated Homey devices to the group
  • Remove each device manually via Forget Device
  • :one_o_clock: Estimated time: 5โ€“10 minutes depending on detection volume
:bullseye: Outcome
  • :tada: Homey flows show up as Alexa scenes
  • :robot: Existing Alexa routines stay functional
  • :man_in_lotus_position: Your smart home remains clean, organized, and duplicate-free
Hope this could help
