I have 2 Qubino Flush relays. A Flush 2 Relay with 2 switches and a Flush 1 Relay with 1 switch.
The Flush 2 works as expected. The Flush 1 however doesn’t switch on or off from withing flows or devices. The strange thing is that in developer.athom.com the device tests okay, and send basic on/off does also work (lights switch on and off).
The relay does show the current power usage from the lights connected to it so there is definately some communication going on.
After turning on or off from devices I get a message "Er ging iets fout, probeer het later opnieuw. (Timed out after 30000ms.)
This happened after a restart of Homey. I since did a PTP for about 20 minutes and rebooted again, but no change, it still does switch on/off from flows or devices.
The relay has always worked before the last 2 restarts and it sits about 3 meters from Homey in the same room (however since basic on/off from within developer works instantly, I don’t think it has something to do with range). The other Qubino relay is working as expected so I’m a bit out of options on what I can do.
PS, switching the light on or off with the switch connected to the Flush relay works fine and quick. And I’m using the 2.0.10 béta version of theh Qubino app which has been working lately
Anyone an idea on to what I can do next or what might be going on?
