I dont recive any pushnotes anymore, in my flows there is a red triangle, What could be the problem?
Without knowing the error it is finding a needle in a haystack with some blindfold on.
Press the triangle (on mobile) or check the bottom of the screen (for web gui).
It probably will be “rate limit”, which means to many messages shortly after each other.
You should also update your topic title, this is very very non descriptive.
I think I win the quiz ![]()
When you hit the red triangle, it should show the error message.
The issue can be “rate limited”, which means there’s too many push messages sent within a certain timeframe.
Wait for 24h or reboot Homey to reset it.
