Problems: self-repeating flow
Maybe good if you check the example in the first post of the Loops app topic: [APP][Pro] Loops.
In order for it to work:
  • You need to initiate the loop. That part you have done in your second screenshot.
  • Then you need to create separate flows for what needs to happen when the loop starts and iterates (based on the WHEN Loop X started/iterates/finishes flowcards). As part of those flows you use the flowcard from your first screenshot that randomly sets the hue of the light.
