Problems after firmware update to v13.5.2, Homey Pro 2023
Hi, Is anyone else having problems after firmware update to v13.5.2 today?
I’ve found that all devices communicating with the Homey Pro 2023 via the local IP network stopped communicating after the update to fw v13.5.2. such as Shelly device, Huawei(Emma), mqtt devices and Homey energy dongle.
I removed the Ethernet adapter from the Homey and connect it via Wi-Fi instead—this is because the changelog mentions changes related to the Ethernet adapter—but that didn’t help.
Has anyone else encountered the same problem?
Br Mike
Does your Homey Ethernet adapter have a fixed/reserved IP-address? If not, it could have changed and the LAN devices are still trying to find Homey on its old IP.
Thanks for the reply.
Yes, the Homey´s Ethernet adaptor is reserved in DHCP(192.168.255.200) and has the same address it has had since it was installed many years ago.
Have done some more troubleshooting.
Disabled IPv6 on the Asus router. I seem to recall there being some issue with IPv6 and Homey a long time ago.
Homey responds to pings locally (192.168.255.200) for a while after a restart, but then stops responding.
Homey communicates and have functions via the cloud—for example, it can turn Zigbee devices on and off—so it is clearly communicating with the internet without any issues.
The local IP address shown for the Homey when checking via the cloud is also 192.168.255.200.
Have now also updated via USB according to Athom’s support. Unfortunately the result is the same.
It’s almost as if a local firewall has been implemented in the latest Homey firmware, causing it to stop responding to things like local pings; this makes it difficult for local devices to communicate via IP:-)
Best regards, Mike
Are other devices effected as well on your home network? Maybe check your router from your ISP and restart those devices as well. Could be just a coincidence but just give it a go :slight_smile:
Thanks. Nothing else on the network is affected, and everything has been restarted a few times—but it has made no difference for the Homey.
BR, Mike
Disable IPV6?
Hope you not using any Thread on you homey network
Thanks, I do, and I’m aware of what doesn’t work in that case. I did it for troubleshooting purposes :slight_smile:
BR, Mike
Can’t relate.
I took the plunge and updated Pro 2026 (ethernet connected) to v13.5.2
(Didn’t reboot it myself, nor pulled the plug for a while).
All my devices, including TCP network devices, work fine.
(I use quite a lot: H.A., ESPHome, MQTT, SMA/Solis/Growatt, Intergas, various cams, Homewizard P1, Slimmelezer, SmartGateways watermeter and such)
Replying to myself—I’ve sent the following to Athom support. Does anyone here have any tips, or will I have to rebuild my entire network (which would be a huge amount of work)? I chose this specific subnet many years ago precisely to avoid ever having to rebuild the network. There are so many dependencies that would be affected if I had to change the subnet. Does anyone know if the AI’s answer is correct?
"Hi
After quite a bit of troubleshooting—including moving the Homey between different routers, where the issue could not be reproduced—it appears that the 192.168.255.x subnet is the source of the problem.
I searched online—“is there some problem with subnet 192.168.255.x on Homey Pro?”—and the AI ​​response was: “Yes, using the 192.168.255.x subnet can cause a conflict with Homey Pro because the underlying operating system (a customized Linux distribution) frequently uses the 192.168.255.x address space for its internal virtual networking interfaces.”
Hmm, I have well over 100 devices on my network, and changing all those IP addresses would mean a massive amount of work. Many of them rely on static configurations—for instance, the Huawei EMMA, where you have to specify—during the commissioning phase—which IP address is permitted to send requests via Modbus TCP/IP. If that AI response is accurate, this is definitely not good.
Is there any other solution, perhaps by changing the addressing locally within the Homey itself?"
Br Mike
This smells like hallucinated BS. I don’t even know what it means with “frequently”; “Homey OS” either uses that subnet, or it doesn’t. And I can’t find any clue that it does.
Hi, thanks for the reply—perfect. I really hope there’s no truth to the AI’s answer and that it’s just BS. No one would be happier than me! :slight_smile:
However, I seem to be able to reproduce the issue I’m experiencing across two (well, three—I don’t want to mess with my primary Asus router) different routers. The common denominator is the 192.168.255.x subnet. These are basic, inexpensive, factory-reset routers provided by the ISP. While Homey remains responsive to pings on the 192.168.1.x subnet, it stops responding when on the 192.168.255.x subnet. Other devices work perfectly fine on these same routers.
If I switch to the 192.168.254.x subnet, Homey works just fine there, too.
Could someone kind on the forum—who happens to have a spare router—see if they can reproduce the issue I’m experiencing? You would need to set up a Homey Pro 2023 (running the latest firmware and using an Ethernet adapter) on a 192.168.255.x subnet. Then, check if it stops responding to pings after 30–120 seconds, perhaps responding sporadically after 10 minutes, only to stop responding again.
BR Mike
Some router’s/modem really dont like to use other ip adresses.
Not sure whether relevant and just a thought, but doesn’t the 255-number have a special meaning in an IP address? As it is also used for masking and broadcasting purposes. Maybe Homey treats a 255-number differently. Do you run into the same issue if you use a different IP range that also included the 255-number?
Hi, thanks for the suggestion.
I switched the subnet to 10.255.255.x, and Homey has been responding to pings flawlessly there for about 10 minutes, so it doesn’t seem to be related to “255”.
BR, Mike
I’m not quite sure what to say about the response below that I received from Athom support. It does, however, confirm my suspicions that the private subnet I chose over 15 years ago was not a good choice.
I selected it with great care specifically to avoid ending up in a situation like this. It’s frustrating that a product designed for home use—one you pay a premium for, precisely to avoid such pitfalls—ends up causing these kinds of issues.
According to Athom support, the 192.168.255.x range is allocated for Thread within the “Homey bubble” and is entirely unsuitable for use in a home network.
Why did I choose this range? As “IT person” for those around me, I assigned `192.168.255.x` to myself, `192.168.254.x` to my mother, `192.168.253.x` to my sister, `192.168.252.x` to my first child, `192.168.251.x` to my second child, and so on and so on. This approach has been extremely convenient, especially when dealing with VPN solutions and the accessibility of default gateways—it really simplified things depending on the specific configuration.
Now, it seems I’ll be forced to rebuild my own entire network. The solution within the “Homey bubble” should, for instance, have been based on `127.0.0.1` and `localhost` (or something similar); that way, this conflict could have been avoided.
Here is what is in the v13.5.2 changelog that likely affected me:
Thread
  • Fixes an issue where all Thread devices could become unreachable due to an occasional address conflict between Zigbee and Thread.
  • Fixes an issue where all Thread devices could become unreachable if Homey Pro is connected to both Ethernet and Wi-Fi.
  • Improves reliability when multiple Thread Border Routers are on the same Thread network as Homey Pro.
Athom’s response to my support ticket (156229):
Hi *Xxxxxxx,
Thanks for your reply!
I have talked about this issue with one of our developers.
It turns out that the 192.168.255.x subnet is used for Thread.
Although it might not be ideal, we would recommend you to use a subnet other than this one for your Homey and LAN devices.
A downgrade to an earlier Firmware isn’t possible sadly, unless you have a local backup of your Homey on that version at https://usb.homey.app/.
For now, this is all I can help you with, which is why I’m closing this ticket.
I wish you a great day!
Best Regards,
*Xxxxxx
(* Something else)
It looks like I’m facing a migration of all my network devices to a different subnet, as well as the need to recreate the relationships between them—relationships that have been built up over many, many years.
I’m posting this primarily because it might be helpful to someone else and shit happens.
BR Mike
Hi again.
Just had to reply to myself :slight_smile:
A reflection on how this could have affected me—well, it could have been much worse than just having to change a subnet.
Like most people, I’ve focused on optimizing my entire home to reduce costs—managing solar power, grid electricity, battery storage, and loads like heating and hot water. In my view, that’s exactly the job a Homey is meant to do.
The fact that auto-updates are enabled by default on the Homey doesn’t sit well with me. Just before an auto-update, the Homey could have sent a MODBUS command to shut down the heating system—that syntax is actually included in my flows.
I could have been on vacation in the Canary Islands, sipping a massive drink, while the entire hydronic heating system back home in the Nordics froze and burst.
This incident reinforces my decision to keep auto-updates disabled; I was the one who initiated the update, under controlled circumstances. That said, I certainly didn’t plan on ruining an entire weekend—plus all the extra work that’s going to follow.
Best regards, Mike
Ouch! I don’t use Thread on my Homey, which is why I couldn’t find that network being used anywhere (although there already is a Thread BR interface, wpan0, on my HP2023, but that only uses IPv6).
But using an 192.168.X.X. network for something “internal” seems rather strange. It is a private network, but there are better subnets to choose from.
It might be possible to fix this issue if you enable IPv6 on your network. That way, Homey doesn’t need an IPv4 address for Thread at all (although I have no idea how/why this mechanism even works on Homey, so I’m just conjecturing).
Thanks for your input.
I had IPv6 enabled on my Asus router before, during, and after the update; the problem still appeared immediately following the firmware update.
As I see it, Homey is essentially a “pig in lipstick” running on a Raspberry Pi-like architecture, with various isolated environments—like Docker containers or similar—running inside.
Honestly, I’m not really interested in that; if I were, I would have chosen a different platform—one that wasn’t marketed as a “ready-to-use” product.
Functionally, however I think, there needs to be local traffic between these internal instances within the Homey unit, and it seems this is where the developers chose “my” subnet to use “under the hood.”
I set up a different Asus router with a 192.168.50.x subnet, along with static routes between the old and new routers, intending to move only the Homey device to this new network.I really don’t want to change my subnet…
I suspected all along that I might just be shooting myself in the foot, and that some underlying communication protocol would likely fail anyway. I’m not familiar with how, for instance, Thread handles communication—or whether it even works across two separate routers—and, to be honest, I have no desire to learn, well, mostly not, anyway! :slight_smile:
The result? As soon as I pinged the Homey (at 192.168.50.200) from a PC (from 192.168.255.103), the same issue occurred: after 30–120 seconds, the Homey stopped responding to pings. It seems the Homey sees the source address and just gets “confused” and stop answer just as before…The outcome was fairly predictable, but since I’ve already invested too much time in this, one more test doesn’t really change anything.
That’s quite a lot of text…:slight_smile: Cheers, Mike
I have nothing to add to this thread, besides this being one of the most insane private IT takes I have ever heard in my life :sweat_smile:
Hi! Perfect—I’ll take that as confirmation that I did the right thing! :slight_smile:
It has served me well.
Br Mike
