Dear Sir,
I own a Homey Pro 2019 and recently decided to perform a factory reset to organize my device network. After the reset, I re-added all devices, starting with those connected to power (routers with neutral). The powered devices were added without issues, but I encountered difficulties when connecting battery-powered devices.
Aqara devices, such as:
- motion sensor,
- temperature sensor,
- two-button remote,
during the pairing attempt display a message about starting the pairing process, but after some time, an error appears indicating a timeout and connection interruption.
Interestingly, other battery-powered devices, such as the Philips motion sensor or the Aqara water leak sensor, were successfully connected without any issues.
Additionally, I noticed that one of the powered devices (router) spontaneously lost connection. I have the impression that when one device loses connectivity, only then can I add another – but in such a case, some other device always stops working.
Currently, I have 50 devices connected, but I am still missing about 10 battery-powered devices to complete the network. I was hoping the reset would resolve the previous connectivity issues, which I attributed to the incorrect order of adding devices (at that time, I sometimes added battery-powered ones before the powered ones). Unfortunately, the problem persists and is becoming frustrating.
I kindly ask for support in resolving this issue. Is there any procedure or guideline that could help in correctly adding the remaining devices?
Thank you in advance for your help
