This is awesome!
Thanks for creating this!
Hope Athom reads along… ![]()
This is awesome!
Looking good !!
Can i also use this outside my local network ?
Yes, you should setup a proxy or VPN.
How can I change the ip-address in MAFE, so I can connect to another Homey-system?
I’ve change that but the Mobile-app Mafe connect still to the test-server and not to the production-server. The serveraddress in the mobile Mafe app isn’t changeable.
You mean you have 2 Homey Pros? on the same network?
1 Homey Pro and 1 Homey SHS
Ah right. mafe.local is just a shortcut. You can use both your Homey ips + port to get to the other Homey.
Alternatively you can override the port in advanced network settings and use mafe.local:8080 for Homey Pro and mafe.local:9090 for Homey SHS
It’s for me not possible to do:
It seems to work a little different than Homey’s flow editor.
Don’t have a proxy or vpn
He is not wrong though I think an extra option ‘connect card’ would be nice to have
You can also port forward that might be the easiest thing to do
Works when adding new cards.
Only how to connect to existing cards?
Yes, for sure
Ill see if I can add both!
Hmm
, yes indeed, there does not seem to be a way currently to achieve that.
Maybe @Kyle_Michiels can explain how to do that.
