[Pro][Dashboard] SmartDash - a dashboard for Homey
v 0.240202.1
  • Fixed regression when clicking widget buttons: now vibration, sound click and spinner are back.
  • Moved button for return to dashboard in bottom bar
  • On nspanelpro, when you go in info page the system automatically checks if there is an update
The forecast is in todo list :wink:
I’ll think about the other functionality!
This is awesome, i did not think about it!
For this,
you would like to insert the power measure into the thermostat widget?
Hello Ralf, did you find a solution to get a bearer token ?
It’s the third time i’ve to copy/past a new bearer to SmartDash since I installed it on my Sonoff (5 days ago)
HOW TO GET BEARER TOKEN IN HOMEY PRO 2016/2019
1) Create this homeyscript:
const email = 'your_mail';
const password = 'your_password';
const client_id = '5a8d4ca6eb9f7a2c9d6ccf6d';
const client_secret = 'e3ace394af9f615857ceaa61b053f966ddcfb12a';
const redirect_url = 'http://localhost';
const cloudid = 'your_cloudid';
const between = function(str, strf, strt) {
    return str.split(strf).pop().split(strt)[0].trim();
const authurl = 'https://accounts.athom.com/login';
const response2 = await fetch(authurl, {
  'headers': {
    'accept': 'application/json, text/javascript, */*; q=0.01',
    'content-type': 'application/x-www-form-urlencoded; charset=UTF-8'
  'referrerPolicy': 'no-referrer-when-downgrade',
  'body': 'email='+ encodeURIComponent(email) +'&password='+ encodeURIComponent(password) +'&otptoken=',
  'method': 'POST',
  'mode': 'cors',
  'credentials': 'omit'
const body2 = await response2.text();
const token = JSON.parse(body2);
const authorizeurl = 'https://accounts.athom.com/oauth2/authorise?client_id='+ client_id +'&redirect_uri='+ encodeURIComponent(redirect_url) +'&response_type=code&user_token='+ token.token;
const response3 = await fetch(authorizeurl, {
  'headers': {
  'method': 'GET',
  'mode': 'cors',
  'credentials': 'include'
const body3 = await response3.text();
let csrf = between(body3, 'name="_csrf" value="', '">');
let raw = response3.headers.raw()['set-cookie'];
let cookiecsrf = null;
raw.forEach(el => {
    let dc = el.split('=');
    if (dc[0] === '_csrf') cookiecsrf = dc[1];
let cookie4 = '_csrf=' + cookiecsrf;
let authorizeurl2 = 'https://accounts.athom.com/authorise?client_id='+ client_id +'&redirect_uri='+ encodeURIComponent(redirect_url) +'&response_type=code&user_token='+ token.token;
const response4 = await fetch(authorizeurl2, {
  'headers': {
    'content-type': 'application/x-www-form-urlencoded',
    'cookie': cookie4
  'redirect': 'manual',
  'body': 'resource=resource.homey.'+ cloudid +'&_csrf='+ csrf +'&allow=Allow',
  'method': 'POST',
  'mode': 'cors',
const body4 = await response4.text();
let code = response4.headers.get('location').split('=')[1];
let tokenendpoint = 'https://api.athom.com/oauth2/token';
const response5 = await fetch(tokenendpoint, {
  'headers': {
  'body': 'client_id='+ encodeURIComponent(client_id) +'&client_secret='+ encodeURIComponent(client_secret) + '&grant_type=authorization_code&code='+ encodeURIComponent(code),
  'method': 'POST',
  'mode': 'cors',
const body5 = await response5.text();
let accesstoken = JSON.parse(body5);
let delegationEndpoint = 'https://api.athom.com/delegation/token?audience=homey';
const response6 = await fetch(delegationEndpoint, {
  'headers': {
    'authorization': 'Bearer '+ accesstoken.access_token
  'body': 'client_id='+ client_id +' &client_secret='+ client_secret +'&grant_type=refresh_token&refresh_token='+ accesstoken.refresh_token,
  'method': 'POST',
  'mode': 'cors',
const body6 = await response6.json();
let endpoint7 = 'https://'+ cloudid +'.connect.athom.com/api/manager/users/login';
const response7 = await fetch(endpoint7, {
  'headers': {
    'content-type': 'application/json'
  'body': JSON.stringify({ 'token': body6 }),
  'method': 'POST'
const body7 = await response7.json()
await tag('access_token', '{ "token": "'+ body7 +'"}');
return true;
This homeyscript estract the bearer token and put it into a tag
2) Create a flow with call the homeyscript every day and put the token into a global variable
https://homey.app/it-it/flow/n-F3VR/
3) Create a flow for send the token in a local url (Is needed this app)
https://homey.app/it-it/flow/l6V3VR/
4) Test the result
If your homey ip is 192.168.1.110 and in Local API you have set port 8066,
the result is a link like this http://192.168.1.110:8066/token that return a json
NOTE: client_id and client_secret are a test user, it can’t full access homey (here it is explained why insights don’t work)
Hey !
Thank you a lot !
It looks like it works for me :slight_smile:
Now I’ve to know how local api works :slight_smile:
perfect!
now you can add this at end of homeyscript:
and you can create a flow like this
and a flow like this
if your homey ip is 192.168.1.110 and with local api you have set port 8066,
the result is a link like this 192.168.1.110:8066/token that return a json
I’m modifying SmartDash app to handle fetching the token automatically
Coming soon.
With new release you can insert an url for polling new token every hour.
Url return a json (from App Local API) where $token is your valid token
{"status":"success","url":"/token","method":"GET","data":{"token":"$token"}}
Hello
  1. So, I’ve added the line to the script:
  2. I’ve created a variable called “access_token”
  3. I’ve a flow named “Bearer” like this:
  4. I’ve installed and create a flow named “bearerSender” like this:
  5. I’ve configured LocalAPI like this:
My Homey’s IP is 192.168.2.253
My Sonoff’s IP is 192.168.2.61
Do I need to configure something else before your next release ?
you need enable cors and add * in it
Open
192.168.2.253:8066/token and check il json has your token
Tomorrow i release the update for testing
Configuration:
Checking access:
I’ve tried with another port and it works !
Local API:
JSON respons:
OK perfect!
I have released nspanel pro version, check if it works (it may take some days to figure out if it works well)
Done !
I’ll give you a feedback !
Thank you a lot for your work !
v 0.240205.1
  • added method for auto retrieve bearer token (needed for Homey Pro 2016/19)
Damn,i think it’s unsolvable
You can remove 142 row
