Poor response time from pressing a HUE light switch to quibino controlled light.
The response time ranges from 3 to 10 seconds.
Anyone a clue on how to improve this.
I have latest homey sw : 5.11
did you connect the switch directly to homey or to the hue bridge?
Devices connected to the hue bridge have a bit latency in responding because of the polling.
And the polling is 7 seconds iirc
Thanks for your hint.
I now try to connect the switch directly to Homey using the philips huie zigbee sw just installed on Homey.
this does not work however; the on flow and off flow tests work well but using the hue dimmer buttons does not work.
any ideas?
best regards Bertus
I understand the 7 secs is a hue bridge feature …so I will now try to connect directly to homey
Hue dimmer switch, more people had some issues with that. I also have one didnt work but that’s was way back, and it ended up in a drawer somewhere. I Will look it up and test it tonight.
mine also isn’t working yet, shows up as an unknown device at developer page.
take a look here: https://github.com/sebbebebbe/com.philips.hue.zigbee/issues/8
People claiming they have working dimmers again so… it should work. i will give it some time and try again later on.
Later —> restart homey and the dimmer is operational
