Please change Swedish translation
I have no idea where to send this, so I try posting it here: In the Swedish translation of the Homey App, the device id is called “Enhtes-ID”. This should be “Enhets-ID”. Please correct this, it looks really weird. :slight_smile:
Hi, Thanks!
Can you clarify where that is? is it in the Default Athom part or in a Community App for a device?
In first case you should send it to Support, (email or link below.)
just add a NaN for the Log ID :wink:
Maybe add a Screenshot (as I as a Dutch have no idea )
For the Community App Contact the Developer.
For support or issue resolution, first have a look at support.athom.com. If you are unable to find the answer to your question on support.athom.com you can send a support request to Athom via https://support.athom.com/hc/requests/new.
If you need help you can read more about how to submit a support request.
When filing a support request, make sure you add all necessary information so Athom can help you as quickly as possible.
Thanks for the information! It’s in the default Athom part, that’s why it’s so disturbing since I see it all the time. :slight_smile:
I will use the support link!
