Please please please can we have a menu collapse/hide button in the web app? Dragging the devices/flows/insights lists/tree out and away is so manual, which seems tedious for an automation system… in that gap between the Homey logo and the Home icon could we have a collapse/ expand button please, to hide the tree/list when not using it, only showing the menu icons, and giving more screen space back when you want it, or to just look nicer/neater on wall displays.
If are in the e.g Flows then just click on Flows and it will collapse
A haaaa… that’s not entirely obvious
and very useful to know!!! Thank you kindly good sir ![]()
It’s not a full solution though: after you click the respective tab icon to re-open the navigation pane, the pane is reset: it does not remember e.g. which folder was opened or which specific flow is selected.
So you have to navigate back to the folder/location that was opened before you collapsed the navigation pane. Currently - in my case - it is quicker to just manually drag the navigation pane to the open and closed position, as that retains the selected folder.
That is also a very valid point… as like me you also have a very large number of Flows and devices etc, so navigating back to your previous place is a bit of a mission. I have multiple levels of sub folders with a numbering system to keep better track of Flows, but it would be a hell of a lot easier if the menu remembered where you were and returned to that place when you re-opened it, instead of of playing hunt Flow number 210 out of 300 ![]()
The “collapse” feature is not consistently implemented depending on your location.
For unknown some reason, it is completely different in the web app compared to the developer pages…
