Let’s go for an other question !
I’m looking for a way to create a virtual PID thermostat (proportional-integral-derivative).
Is it possible or should i buy a real one to do the job ? And if i buy a real one, which one ? is it capable of handling multiple room ?
I would always go for a real one, no dependency on Homey but managed by Homey for Setpoints.
Honeywell evohome does the job here, but tado° also delivers a multiroom or zone system and talks with Homey.
Depends on more than these two questions, type of heating and does it use OpenTherm or …
I don’t know what algorithm the virtual thermostat app [APP] VThermo is using, but if you ask the developer he might be interested in implementing it. However, I doubt a virtual thermostat can control the actual heater well enough to have the kind of control you are seeking.
I second Dijkers comments and am a happy Tado user with multi zone control. Homey does additional logic for individual family members, real open window detection and more. One thing to note with Tado, if internet is down, you’re back to manual control, not even basic clock thermostat functionality left. That could be a deal breaker for some.
As far as I know the VTthermo app, Virtual thermostats and also actual thermostats are all more or less based on “hysteresis” control. Please proof me wrong
In other words the heating is on when the set temperature is higher than the measured and turned off when the temperature reaches the set temp+hysteresis. Actual thermostats have also some on/off timed switching (They say its PWM, but made with relay/contactor) when the off limit is close, lets say 1C away, so that the temperature doesn’t overshoot the set temperature.
It would be great to have PID controlled thermostat, virtual or real one. That way you could finetune the heating so that the overheating and underheating could be minimized. Of course the tuning is still quite long process to do, because you have to adapt to winter/summer, moist/dry and so on.
Of course you could do the PID with Better Logic calculation or Homey Script if you have the time an skills to make it, but it would be nice to have for example additional app for it to make it easier to use.
True, but as Dijker mentioned, you need something to control the heater itself. So what will be on the other side of the virtual thermostat? An Opentherm interface? And what is connected to that to send whatever fine grained commands? And why would Homey be able to do better than smart dedicated thermostats?
I think the question is too much thinking outside in - it all starts with what is producing the actual heat, and how is that controlled before you can look at how Homey interacts with it.
Sure, but on/off modulation is a bit back to the stone ages for modern devices, and it does not seem that this is what @jeremypsl seems to be looking for.
Devices that only support on/off are more common than you think, especially outside NL. However, judging by his latest comment, I think he’s heating his home electrically (also fairly common in certain countries).
@jeremypsl can you explain your heating situation?
I would also like to implement a PID regulator to control the indoor temp based on the derivative of the outdoor temp.
We had an analog system like that in the sixties/seventies to control the heating in or house and it was excellent. When the heatpump/element thermostats react indoor, it is already too late.
So if we take it in steps, the first one being to implement the PID sw and then later add the “Control bit”
(and yes, i can control the temperature setpoints)
I am also looking for a smart way to control (regulate) my waterbased hesting, as the hysteresis way is reslly poor due to the slow process. Would love to have a simple way to set the pulse-lenghts relative to the outside temp and the offset to the setpoint temperature.
When/if it is possible to achieve a good regulating system, this could also been made to be a predictive system based on future temperatures:-)
Anybody interested in developing such an app? I’ve already tried to get ChatGPT to develop a Homeyscript that solves this, but have not been able to get a good working solution.
Secure HRT4-ZW (previously SRT321) is a battery operated TPI-thermostat with selectable cycles per hour (3, 6 or 12 times). I have 4 units at my cabin controlling the electrical wall heaters with 12 cycles per hour. Excellent control algorithm gives very stable temperature, within ±0.1C. The only problem is the somewhat short (2-3 months) battery life (2xAAA). Instead I use 3500 mAh 18650 type usb-rechargeable battery (I added 3V regulator on output) which gives 6-7 months between charging.
