Hey Homeys ![]()
I recently bought a Nest Learning thermostat, But now I want to control my climate temperature per room. I wanted to do it by using Tado Radiator knobs and the Nest thermostat as a central controller for my central heating.
But here comes the problem: Nest canceled the Api, But I was thinking that there must be a way around it. I have thought of a solution but I wanted to run by you guys! (before I buy all the sensors) And I donโt really know if it works ![]()
My thought:
I wanted to add Temperature sensors in every room, on the opposite side of the Tado radiator buttons and make a flow that starts it until the temperature is met on both sensors.
And make an automation on the side in GH to start the home/away automation (and duplicate it in Homey for taco) so that they start the same.
Do you guys think that this will work?
