PAX, Bluetooth, Stability
I have a Pax Calima that is connected to its own app. There is also a PAX app in Homey which is connected as well. I am using a motion sensor (Hue) to activate boost on the Pax Calima, but I find that this only works occasionally. Can anyone confirm or deny whether Homey’s Bluetooth is working?
You can add a push notification card after the motion trigger, this way you can check if the trigger has fired. If the trigger card triggers correctly, the issue is in the PAX device/app
I know. But trigging is not the problem. I changed the “so” to fire other things that works. The question is how polite the bluetooth is?
How close is the device to Homey?
Close. 5m i guess. Outside the bathroom.
