Problems are shown by Aqara but after a bit of research it is the ikea routers that are the root cause
Two thoughts:
Will there be a list of “officially” supported brands/´vendors?
Will there be any possibility to add downloaded FW and update manually?
I thought the ETA for the OTA updates for Matter was Q1 2026? If so, then Q1 2026 is an awfully long quarter this year… Strange they cannot get it done. I have seen some Ikea devices being upgraded via Apple Home. But the point of buying an Homey was to get everything in one box…
Based on what do you conclude this
Abe from Athom indicated this week in the latest edition of the Homey Podcast, as well in a.o. this topic, that the OTA functionality will soon be released. I believe they first need to release firmware v13.2.0, which is currently in the release candidate stage.
At this point, we’re in the internal testing phase. The main bottleneck has been Z-Wave, not Matter. Since we’re also testing new Z-Wave firmware and implementation, we want to proceed carefully to avoid breaking anything on your end.
When OTA updates gets pushed to beta it will probably be there for a while, giving developers and partners time to implement and validate the functionality within their apps before we roll it out to stable.
Fair enough. “Not getting it done” was too harsh and uncalled for. But It takes way longer than earlier announced. But I do am a bit frustrated that Homey is not the last hub I will ever need at this point.
Will it also be available on my Homey Pro 2019?
OTA updates will be available on Homey Pro (Early 2023), Homey Pro (2026), Homey Pro mini, Homey Self-Hosted Server, and Homey Cloud when used in combination with a Homey Bridge.
Since the bridge uses the same radio hardware as the older HP’s (so hardware limitations isn’t an issue), I guess it’s a business decision not to make this available for the older HP’s?
It isn’t an issue with the hardware, but the software. As the older gen Homeys use a different stack it requires significant effort to also get it working on the older generations.
You’re in dream land if you ever think that you’ll be able to have your cake and eat it with “one hub to rule them all” in the smart home space
I have a Homey Pro (2023), a Phillips Hue Bridge Pro and I keep an Aqara M100 handy, because Aqara will never open up their firmware to other ecosystems.
In the future, IFFFFFFFF IF IF Homey finally start supporting third party Thread radios natively with Homey SHS, then I’ll be moving the vast majority of my smart home over to Homey SHS on an Intel NUC + a good third party Thread radio, then my Homey 2023 will be for Zigbee products that can’t be supported by the Hue bridge.
Even if you had everything solely in Apple Home, you’ll need a border router + you’ll end up buying the upcoming HomePad + homepod minis in multiple rooms
So that’s hardly “all in one box” now is it?
It seems you’re not quite familiar with Athom’s infamous ETA called Soon ™.
This means as much as “when it’s finished” ![]()
It would help if you mentioned the type of device. According to the firmware versions and the descriptions it looks like you are updating Ikea battery powered devices. These can require several retries.
This might help:
Push the pair button on the battery powered device before starting the update, and keep pushing it about every other second (to keep it awake), until update succeeds.
There all Ikea Matter devices. Had them in Apple Home before. Updates were going smooth there. Not so much here…
Doesn’t do anything…
I believe we need to give Athom some time. It’s the first release, they need time to learn from the real life updates and adjust what is needed.
I trust Athom regarding this.
I had to try several times but upgraded 3 IKEA Myggbett sensors. Nice!
