I needed a Zigbee outdoor plug with metering and found a Osram Smart+ outdoor plug on Amazon. One reviewer wrote that he had it included as a generic Zigbee device in his Homey 2019 Pro (same as mine) and all metering functions worked. After a bit of faffing I managed to get the plug included in my Homey I saw that it is identified as a Ledvance Plug Compact EU EM T in dev tools (EM= energy monitor?). Turns out that I already have one of those but labeled Ledvance.
However, for me there is no metering data for any of those plugs. I installed the Osram Smart+ Homey app and tried to use it to include the plug, but I got a message that there is no app for the device so it will be included as a generic device.
Does anyone know how I can get the monitoring to work? If it’s not possible I will have to return the plug, since the monitoring feature is a deal breaker for the application I need the plug for.
I asked AI to help me and “we” were able to confirm (using Interview in dev tools) that the plugs are sending the metering data to Homey. So this is not a plug issue…it’s something wrong within Homey.
What throws me off is the reviewer on Amazon that writes that he included the plug as a generic Zigbee device and yet have all the metering. This is his review:
“Very satisfied. It goes in as “generic” in Homey Pro and you can monitor both energy use in kWh and Watt and all other functions are there too even though there is no special app (neither Osram nor Ledvance).”
I’ll do some more testing with the Osram and Ledvance apps to see if I can get them to include the plugs correctly. The Ledvance plug has never had any metering…to be honest I didn’t even realise it is a monitoring capable plug until I saw it next to the Osram plug in dev tools and noticed that both were marked the same under model ID.
Maybe they mean the Tuya generic device (when you have a Tuya Zigbee or MultiMode gateway)? OSRAM/LEDVANCE are Tuya based AFAIK, so a Tuya gateway might work.
…and the plug is included as a simple on/off switch. In this case Homey have all the data it needs to display the energy consumption of the device, so why won’t it do it?
I hate this with Homey…you get an error message that makes no sense. I literally used the dedicated app to do the inclusion for the device and Homey slaps me in the face with message that basically is a lie. Why do Zigbee Homey apps even exist when Homey just ignores them and label all Zigbee devices as unknown? This has happened to me with several Zigbee devices from plugs to light bulbs.
I have been a Homey user long enough to know that I will not get any help from Athom or Osram/Ledvance…they will blame each other and I’ll be stuck in the middle, so I really hope that someone in the forum can help me.
I have four other Zigbee plugs that Homey happily displays the metering data for. Those are indoor plugs, so I can’t use any of those to what I need the Osram/Ledvance plug for.
Since the data is present in the report after an “Interview” in Dev tools it can’t be a protocol issue. Evidently the plug sends the data and Homey receives it and reads it correctly…but for some reason it won’t display it for the user.
But you probably paired them using a Homey app that supports these plugs, right?
With a few exceptions, every smart device requires a corresponding Homey app to function properly.
All devices are identified by what is known as a device ID. If this device ID is already supported by one of the relevant Homey apps, the required device driver will be installed.
However, if this device ID is not supported by any of the apps, which seems to be the case here, the device will be added as a generic Zigbee device, and only standard functions such as On/Off will work.
And if a Homey Pro (early 2019) generally doesn’t support the measurement feature for generic Zigbee smart plugs, which I don’t know, but Sven says, then you’ll definitely need a compatible Homey app, or this outdoor plug will need to be added to an existing app.
That’s why I recommend contacting the app developers.
No, that’s not quite right. As far as I know, an interview can be done with any paired Zigbee device. What matters is which capabilities the device uses.
I see…so the new Homey can display energy data from generic zigbee devices? I wonder how much work it would be for Athom to copy that code to work with the old Homey.
Anyhow…I looked a little closer in the information of the Ledvance app and found that there are no flow cards that uses the energy metering…so I guess the reviewer on Amazon have the new Homey Pro. I wish he had specified that. I’ll send the plug back and do a review clarifying that for other potential buyers with the old Homey.
I will giva a Nous plug a chance. I have a couple of Nous zigbee plugs that do have working energy metering, and I found an outdoor plug from them. This time I checked the Nous app and the plug is indeed supported and have flow cards that uses the metering.
I’ll report back if I hear anything from Ledvance if someone else happens to find themself in my situation in the future.
