I have a really small issue with my fibaro relais switch and opening my garage. I have a relatively old garage door which is operated with a remote and/or a pulse switch. I have successfully connected the fibaro relais switch (in the pulse) and have been using it for a a few weeks.
The integration with HomeKit also works just fine.
BUT
The only thing that really hurts my OCD brain is the following. In order to open/close the garage door I have to say: hey Siri/hey google turn the garage door on. I know it’s a small issue but it just feels dumb to say that. I would really like it if I was able to say open/close garage door.
My temporary solution is using Siri Shortcuts, Webhooks and a flow. And naming the shortcut openthegarage. It works 60% of the time. And when it does with huge delay.
Is there any workaround. Or perhaps a different module I should use?
Thank you in advance and have a great day!
configure flow so when i ‘‘close’’ curtain the relai switch turns on
remove fibaro relais switch from homeykit.
i havent been able to add/see the virtual roller shutter in homekit.
it also doesnt show up in my devicelist under the homeykit app in homey.
am i missing something? does it take some time to update? or is perhaps the chosen shutter not supported by the homekit app.
any further assistance would be greatly appriciated!
I tried this and when I Ask Siri “Doe Test omhoog/omlaag” it turns on/off the light.
I created a Curtain Device with up/down/stop.
Did you add the device in the settings of the homekit app on you’re homey?
What I did was the following:
Homey—> add device —> virtual device
Select device—> set name —-> choose curtains ( also tried roller shutter ) —> select op/stop/neer
After that I created a flow that when the virtual device is set to up or down to turn on the relais switch.
When checking the homeykit app within homey I can see all devices that will show up in HomeKit but not the new created virtual device.
i was using homeykit, no i have removed homeykit and installed Homekit app. i might have screwed myself over here since now homekit wont find homey to pair with lol
I dont know how or why, but in my case I have Fibaro relay named “Gate” used for electric gate opening. When I say “Hey Google, open the gate” it works directly without any virtual buttons.
Edit: tested it and no, its not working anymore. I swear that it worked before Now only “turn ON” or “run the gate” works.
I am having the same ‘issue’
I also have an aqara door sensor attached to see the status of my garage door (open or closed), I would like to combine the sensor and my relais switch into homekit.
(I don’t always use homekit, sometimes the physical button or the remote)
For the time being, I made a scene with name ‘Garagepoort’, so I can say ‘Siri Garagepoort’
But If I could add the 2 devices into a virtual garagedoor would be nice.
I discovered that Homekit only accepts a garage door when it has the properties of ‘up-stop-down’ and also ‘position’
I used to have a VeraEdge, and on that platform there was an app called “Garage Door” . In this app you could simply configure which device to use as “switch” and which sensor to indicate open/closed. The app was then visualized as an open or closed garage door in the Vera UI AND in the Home-app on iOS through HomeBridge.
Would be really great if someone with programming skills could do something similar for Homey.
