Nuki Smart Lock Ultra
Hello, do you know if we can connect Nuki Smart Lock Ultra with the app ?
The app does not find the device.
Nuki web is activate.
Merci.
Laurent.
Have you searched the forum or read the specifications?
If it"s Matter enabled you don’t need an app, Laurent. Just pair it.
Connected with Matter, seems ok.
Thanks for your help
This lock is complete new. So the app is not updated i think. Its also only sold at nuki at the moment. So be patient. Or use matter
Did it work with matter?
Matter is not connecting with my nuki ultra
At which step stops the process?
And did you read the ‘known issues’?
Like I wrote, Matter devices don’t need an app, apps don’t need to add support for Matter devices.
But confusingly, there are apps out there ‘supporting’ Matter devices.
After scanning the matter code he didn t sync with the nuki
Android phone?
Did you put the lock very near to phone and or Homey? (Initial connection = per Bluetooth)
Which Thread border router did you select?
What is a border router?
No iphone
I have got a homey pro 2023 I think that s the problem
It’s in the manual I linked to, Johan.
You can choose to use Homey’s thread border router, or IOS Thread border router when you use iphone (Athom calls it Thread network for some reason)
Can you please answer all of my questions, else I’m not able to help, and then we’re both just wasting time:
You wrote
I don’t see how.
That’s the only available model supporting Matter.
I selected the homey pro router.
And my homey pro router is at 3 meter distance
OK, thanks, Johan.
Try to reduce the distance between the lock, phone & Homey to max 1 meter during the pairing process
Thanks that was the problem
Hey, anyone managed to get it working?
When I go closer to the homeypro with ultra then it connects ~kinda, never kinda succeeds but then the lock appears to some extend in homey BUT later when I move out of homeypro range then the lock operations never function again.
Anyone have some working scenario?
Sounds like ‘out of bluetooth range’? With which protocol did you connect it?
Hey, I was trying Matter based integration.
I see. How many meters between your Thread border router and Nuki? Any walls in between?
