Nuki bridge needed?
Do I need the Nuki bridge to pair the Nuki smart lock pro (5th gen) to Homey, or can I connect it without this extra bridge?
I just installed the new Ultra. I do not know if this is the 5 gen.
It works great without bridge. Was connected in minutes (make sure you create a Nuki web account first).
The ultra is the higher priced full replacement brother of the pro gen 5.
Did you connect it using Wifi or Thread?
I guess when connected through Matter-over-Thread you don’t need a Nuki web account?
I used the Homey Nuki app. So I am not sure if it is mattter. I did need the Nuki account , otherwise I did not see an new device.
I remember reading somewhere (I think it was in the best buy guide) that directly pairing was only possilbe using Wifi and that thread required the bridge.
Though I could be mistaken.
True for older models, but the latest lock models don’t need a bridge anylonger.
Locks with Matter support are available with older models as well, which also omits the need for a bridge.
I’ve a gen. 4 lock paired with Matter via Home Assistant+Google Hub Thread border router, and via MQTT, no bridge here.
Then I assume directly pairing a gen 5 with matter over thread should be possible as well.
Sorry, I just edited my post. Forgot to mention the lock is Matter connected to Home Assistant.
But, that shouldn’t mean it won’t work with Homey Matter. It supports locks.
