Notification about power outage in 2025?
Hi, I have a question for you. My Homey Pro and router are powered by a UPS, so I’m not worried about outages or interruptions in the power supply. However, I have no idea how to create a flow that would notify me about such a power loss. Do you have any solution?
You could use a bulb and a battery-powered light detector - perhaps placed in a box for reliability. When the bulb goes out, the power supply has failed.
Andy
Shelly has current meters, place one aroujd the power inket cable.
(Make sure the aqara is connected to the UPS). When current goes
To zero you know the power is out
Can you specify what model you are talking about? Because most of the ones I’ve seen are on a DIN rail.
Is that a problem? (its close to where you want to measure).
You can run a cable from the UPS to the DINblock to feed it
Dont know the specific ones, I just remebered I ran into them searching for Shelly products
