Timmm
January 13, 2025, 12:24pm
1
Hi Homey friends,
In my telegram chat I receive a notification once in a while with
Not Found: FlowToken with ID homey:manager:logic:[string with numbers].
How can I find out what flow is broken here?
Besides of course checking all manually…
Gr. Tim
Hi Tim, did you already take a look here: flowchecker
Besides this checking enabled and disabled flows you might use this HomeyScript:
// Function to get and categorize flows
// Author: RuuRd van der Noord
// Date: 2025-01-06
async function getAndCategorizeFlows() {
try {
// Fetch standard and advanced flows from Homey
const [aStandardFlows, aAdvancedFlows] = await Promise.all([
Homey.flow.getFlows(),
Homey.flow.getAdvancedFlows()
// Initialize arrays to hold categorized flows
const aEnabledFlows = [];
const aDisabledFlows = [];
// Iterate and categorize flows
for (const flows of [aStandardFlows, aAdvancedFlows]) {
for (const flowId in flows) {
const { enabled, id, name } = flows[flowId];
if (enabled !== undefined) {
(enabled ? aEnabledFlows : aDisabledFlows).push({ id, name, type: flows === aStandardFlows ? 'standard' : 'advanced' });
} else {
console.warn(`Flow with ID ${flowId} is missing or invalid.`);
// Output the results for enabled flows
console.log('// Enabled Flows:');
console.log('const aEnabledFlows = [');
aEnabledFlows.forEach(({ id, name, type }) => console.log(`{ ID: '${id}', Name: '${name}', Type: '${type}' },`));
console.log('];');
// Output the results for disabled flows
console.log('// Disabled Flows:');
console.log('const aDisabledFlows = [');
aDisabledFlows.forEach(({ id, name, type }) => console.log(`{ ID: '${id}', Name: '${name}', Type: '${type}' },`));
console.log('];');
} catch (error) {
// Log any errors that occur during the flow retrieval process
console.error('An error occurred while retrieving and categorizing flows:', error);
// Call the function to execute the flow retrieval and categorization
await getAndCategorizeFlows();
Timmm
January 13, 2025, 3:24pm
3
Thanks Ruurd,
Maybe this one is the problem. Is there any way, beside digging my memory/thinking what this tag(?) was?
Well resting with the cursor on this unavailable object/variable will not show anything.
What I do to avoid getting stuck is to create screendumps of every Flow (part).
This does not help you now, but anyway it is a practice that can help you in the future …
Oh yes, when you delete objects/variables/etc. think first …
