Ah sorry, the app I use is Virtual devices.
You can do the following after installing the app:
- Create a Device.
- Add name and image.
- Select device class as Solar Panel.
- Add both Power meter and Power.
- Add a PBTH device with Energy summary for the device you just created.
- Change the settings for the PBTH device to have source as Watt.
- Create a flow similar to my last post to update the Power and Meter power values and you should be ready to go.
