No devices with the xxx capabilty were found
So when I ask homey what the temperature is, the answer is ‘no devices with the temperature capability were found’.
That’s strange because I do have a proper functioning Anna and a Fibaro motion sensor. In the app both devices state the correct temperature.
Also when I ask homey to dim the lights, same thing happens, no devices with the dim capability were found. I have a complete hue setup and some Fibaro dimmer 2’s. In the advanced properties the dim functionality is correctly set.
Anybody know what’s causing this behaviour?
I’m having the same issue, did you manage to find a solution?
Same here with 2.5.2 .
Does anyone have a solution?
