πŸŽ‰ New Homey App to Control Flair Vents – Looking for Beta Testers!
Control your Flair smart vents, pucks, and rooms from your Homey Pro.
App link: Flair | Homey
How It Works
This app connects your Homey Pro to your Flair system through the Flair cloud API. When you adjust a vent or set a room temperature in Homey, the command is sent over the internet to Flair’s servers, which then relay it to your Flair Puck or Bridge at home. The Puck or Bridge communicates directly with your vents over radio to carry out the command.
Because the app relies on the Flair cloud, an active internet connection is required for Homey to control your vents. If your internet goes down, your Flair system will continue to work on its own β€” you just won’t be able to control it from Homey until the connection is restored.
What You Need
  • Flair Smart Vents β€” The motorized register vents that replace your standard floor or ceiling vents
  • Flair Puck or Bridge β€” Acts as the local hub in your home, communicating with your vents over radio
  • Flair Account β€” Required to connect the app to your Flair system
  • Flair API Credentials β€” A Client ID and Client Secret, which you can obtain by contacting Flair support or visiting flair.co
  • Homey Pro β€” Running firmware 5.0.0 or higher
Supported Devices
  • Flair Vent β€” Control vent position, view duct temperature and battery level
  • Flair Puck β€” Monitor temperature, humidity, light level, and pressure
  • Flair Room β€” Set target temperature, monitor current temperature and humidity
Flow Support
  • Trigger: Vent position changed
  • Condition: Vent is open/closed
  • Action: Set vent position
Setup
  1. Install the app on your Homey Pro
  2. Add a device and enter your Flair API credentials (Client ID and Client Secret)
  3. Select the devices you want to add
The app will automatically sync with your Flair system every 30 seconds to keep device states up to date.
