I am about to exchange my Dashboard Controller app with the newly added Fully Kiosk Browser app. One command I am missing is the Dim to-functionality to set the dimlevel, that is available in the DC-app. Could that be added @Emile?
If you contact them about this and get a response, please let us know… I too would like to update to the new app if and when it supports screen dim level, and volume level.
Thank you kindly ![]()
Will do and will update here if I get an answer.
Thank you, appreciated good sir ![]()
I downloaded this new app too, but was unable to add my tablet.
Can not find this setting that onboarding is requesting “Enable Remote Admin Advertising by mDNS-SD”
Also, the search doesn’t find that setting.
I have the latest version of FKB, a Plus license and Remote Administration enabled.
The other app does find it though.
Anyone got an idea?
Thanks, @Borssie. Somehow the Play Store showed no update, so I was still on v1.5.7. After installing the .apk from the Fully website, the setting appeared.
I don’t see how to use this app.
Is it for an other dashboard then the Homey dashboard or can it load the homey app?
See
I know the app. But I don’t the use case for Homey. With Home Assistant I know how to use it. But thought homey has no web based dashboard
I use it to open the Homey app on an Android tablet and show a Dashboard in kiosk mode when I’m in the room… and put the tablet to sleep when I’m not in the room. It’s capable of loading an app and running it in kiosk mode over the top of the browser.
Plus, I have a Shelly Wall Display XL, that despite having support for the Homey app, it runs like a absolute garbage (so slow it’s unusable) so I use the most excellent WidgetKeep app that enables web dashboards and runs absolutely brilliant on the same said display.
EDIT: oh, and it also dynamically changes the screen brightness for me depending upon the lux reading from an Aqara FP2 presence and light sensor. And enables DND when I go to sleep ![]()
Hi @Drako74!
Are you saying you’ve found a way to change screen brightness using the New Fully Kiosk Browser app? I’m still using the Dashboard Controller app to do that.
Ah sorry, my bad, I didn’t realise which app version I was commenting on… been so long since we all commented about adding that functionality to the new app I’d forgotten about it to be honest. I too am still using the old Dashboard Controller app for that precise reason. I was hoping that this new app would get more support and development, as it looks like a nicer design and more stable than the old one.
