Namron dimmer turns itself on
The last couple of days, I’ve have a problem that the app or the device itself is turning the dimmer on.
This is the information about the Z-wave dimmer:
This is the product:
Namron Z-Wave LED Dimmer 200W, 1402756
2 days ago, you can see it’s only been set on/off by the flow.
Then, it started to be set on/off by “Namron” and I had to manually turn it back on/off.
Could it be a physical problem (the knob or the rotary mechanism)?
i have the same problem. the flow turns everything off, and then namrom turns back on a few of the zones by it self…
Did you find a solution to this? Have the same problem
It hasn’t happened in a while, but I have no solution for it.
