My flow keep getting deactivated
I have an advanced flow to go when someone set the phone to “Do not disturb”.
Several times lately this flow has been deactivated, and I don’t understand why. What can I do to stop the ap from getting deactivated?
to guess is to miss …
Share the Flow,
Show a screenshot.
I’m sorry it is in Norwegian, but I hope you can figure it out still.
It is turning of lights, locking door, and turning off some heat. It worked all fine until a few days ago, and I discovered that it is getting deactivating.
A loop has been made in the last 4 cards line.
That line is started by the 1st one and then repeated by 10 minutes timer.
Further a tip: change the two “0 sec timers” in “Any card”.
Thanks, I’ll try this. I’ll come back and let you know if this was the solution.
Thanks also for the tip on the “any” flowcard.
