Multiple events on timeline even though only happens once
Hello!
Almost every time I come home the app registers multiple events of coming home. And also leaving.
Please look at the screenshot. During those events on the timeline I only came home once and left once about ten minutes after.
What to do?
Andreas
You could have multiple flows marking your status?
Not that I know of. I am very new to this and those events on the timeline should only be due to my telephone’s location.
But I could be wrong. The only flow I have is for my lights to turn on when I come home. But in that flow the “when” card is when I come home. This wouldn’t create three events of coming and leaving home, would it?
Have you checked the Location setting in Homey to make sure it is accurate?
Just thinking it could be on the edge, so Homey thinks you have left and come home.
@Adrian_Rockall thank you for the tip. My location was correct but I moved it just a little to se if that does anything for me :blush:
I don’t use the location option.
But maybe you can add a light to the flow that turns on or off when you come home or leave the house.
Maybe there is something with the Timeline message that it is send with a delay twice.
And maybe when the light turns on when coming home then turn it of manual and see if it turns on again if you are not leaving the house.
So you can see when it thinks you’re coming home.
But maybe this test makes no sence, this was just a idea.
In my case it’s my home mesh network.
When i walk through my house my phone switches from 1 mesh point to another.
In that case my phone looses connection for a short period and Homey thinks i am not at home.
My wifes phone (which brand and type is the same!) does not loose connection and thus she is constantly home, as long as her phone is anywhere in the house.
Maybe that could be it! Weird though that your phones behave differently. I must check my fiancé’s phone now that she has joined. :blush:
I thought Homey checks your wifi AND phone location. When I only disable wifi on my phone, I am not marked as ‘away’ by Homey Location…
Maybe you use the app Smart Presence? That one works with Wifi only, but that one has a ‘blind time’, to prevent in/out triggering because of hopping to AP’s
