Motion Light Flow
Flow 1 to 4 is more or less a standard for my Light automatic.
Flow 5 and 6 to deactivate/ activate the automatic switch off.
Flow 1
When Motion alarm goes on
And light is off
Then switch light on
Flow 2
When motion alarm goes off
And Light is on
Then start Timer with 120s
Flow 3
When Timer reaches O
And no motion
Then switch light off
Else
Start Timer with 120s
Flow 4
When light is switched on
And no motion
Then start timer with 120s
Flow 5
When S2 1-Klick
And Light is on
Then deactivate Flow 3
Else
Deactivate Flow 3
And switch light on
Flow 6
When light switched off
And Flow 3 is deactivated
Then activate Flow 3
The same you can do to prevent the light to be switched on automatically.
Flow 5*
When S2 1-Klick
And Light is on
Then deactivate Flow 1
And switch light off
Else
Deactivate Flow 1
Flow 6*
When light switched on
And Flow 1 is deactivated
Then activate Flow 1
