I like to migrate my Migrate Homey Self-Hosted server to Homey Early 2016. How to do that?
Best regards
Best regards
That’s not possible, you need to set everything up again on the Pro 2016. You can only migrate between Homey Pro’s (with a cloud backup subscription), but not between Homey SHS and Homey Pro
I did a migration from Pro 2023 to SHS.
Maybe my experience can inspire you.
Devices:
Create the same devices on the new Homey.
Create and run a script that collects the old UUIDs for use in the migration tool* you prepared.
Variables:
Recreate them with the same names using a script created for this purpose.
Make sure to use the correct types and supply initial values.
Flows:
For devices from 2023 and later, you can use:
Flow Converter
[EDIT: Or just paste the scripts to files on your computer. … moved to Scripts]
Export the flows from SHS, then you can run the old versions through the migration tool to replace the UUIDs and create the new flow versions.
Inline scripts will be migrated within the flow.
Import the migrated flows. I am not sure this is possible in 2016, though.
Scripts:
There was a topic on how to collect the scripts with Developer Tools:
https://forum.athom.com/discussion/3666/homeyscript-share-your-scripts-main-discussion-topic
[EDIT: Or just paste the scripts to files on your computer.]
Run the old and new script versions through the migration tool in much the same way as the flows.
Restore the scripts on your new Homey.
Keep in mind that scripts also receive new UUIDs.
Validation:
Run the flows in a safe/test state first.
Creating the scripts and tools, as well as performing the migration, took me a day’s work.
Also: You need to be aware that the Homey Early 2016 does not support all the functionality of Homey SHS.
Correction:
The script to collect your scripts from your Homey with Developer Tools is here:
Backup Script For Homey-Script
too bad, I am a rookie and not able to do this
too bad, Inproceed SHS
too bad but have not detected it
