I never had that issue, strange. I moved to a new place and do not own a Mertik fireplace anymore. Sorry to say that I cannot continue maintaining the project ![]()
Just an update, my changes that are running on my Homey and working are located here: GitHub - obel-org/homey-mertik-wifi: Homey plugin to control Mertik Wifi Connected fireplace
For now I will also not distribute to the store.
Did you manage to get it controlled, by the pins of the panel interface?
The “wandschakelaar” is connected with same pins.
I would like to simulate the “wandschakelaar” actions in Homey.
Up - Down - On/Off
Did you manage to do that with relais in Homey?
Hi @petero-dk ,
Do you think the App will work with the latest Wi-Fi model? see B6R-W3MR Wifi Box Maxitrol • SDM Parts
If it does, I want to buy it.
Regards Paul
I have no idea, since it seems to be using the same app, it should work. But no guarantees.
Ok, I will try and let you know ![]()
Eindelijk ben ik er aan toegekomen, echter krijg deze error als ik de App probeer te installeren.
(node:12456) [DEP0040] DeprecationWarning: The punycode module is deprecated. Please use a userland alternative instead
Kan dat kloppen? wellicht veranderd in de tussentijd.
Die melding krijg ik ook bij het starten van mijn apps. Deze melding kan je negeren, de app werkt verder hetzelfde
Ik krijg de melding tijdens een “poging” om te installeren, vanavond nog eens proberen….
Mogelijk is er dan nog een andere fout die optreed, maar deze melding:
zou de installatie niet moeten blokkeren.
I am not sure what you are saying, is it working for you?
Yes it works for me ![]()
Sorry I posted in Dutch ![]()
