Measure_power_changed?
homey:device:4f88a0c7-e1a7-4823-b219-307a1605cca4
homey:device:4f88a0c7-e1a7-4823-b219-307a1605cca4:measure_power_changed
I´m new to Homey and today I came home to a not working flow.
I used the card measure power change on a neo plug.
Why is that card deleted, has it something to do with the update this night?
Can someone help me with what I should use instead?
Good community…28 views and no response. WTF
Here’s a reaction…
Well, let me check my :crystal_ball: … hmm, seems to be defect :upside_down_face:
  • Is the device still present in Homey?
  • Is it “unavailable”?
  • Is the app running or stopped?
In most cases, the used app is stopped/crashed.
Sometimes due to Homey memory usage (too many app running, no free memory).
Btw… nice community - wish you a nice evening, too.
Device is still working. App is working.
Just this single block function mesure_power_changed that disapeard “grey with the error code I posted”
The flow card ist still present in your flow, but inactive with error caused by missing trigger?
Then it seems, this was removed from the app.
Was the app updated - did you mean an app update last night? Or Homey update?
As it seems it’s app related. You can create an issue on Github
…if you are using this app(?)
Thanks for your tips!
My Homey Pro 2023 was updated.
I use this app for a Neo plug. (NAS-WR01B2)
Hm, Nous app for NeoColcam plug?
If it’s a Zigbee plug, I would suggest to add this device as standard Zigbee device without an app.
On/off and energy metering is supported this way for default Zigbee attributes.
Thank you! I don´t know why I used this, but now it workes again with regular zigbee. Have a great evening!
