Is it possible to set up the mini dimmer so that a wall rocker switch will turn the lights to 100% in one dire3ction and off in the other?
It seems counter intuitive that the current setting of flicking the switch ‘off-on-off’ is required to turn the lights off manually.
it is working like your proposing at my house. if you look at the advanced settings you can choose the wall switch type (top setting) i think if you would change that, its working as you propose. (dont forget to wake the device up, to enable these settings)
Brilliant, thank you
