I have designed a flow in Node-RED, where a webhook is created using mobile IP (fritz.box -> device presence check). With method “get” the URL is sent to homey.
With homee works it perfect since months without any problems.
How exactly does the URL have to be structured in order to work with “logic - a webhook has been received” with homey?
My sample URLs: (event = anwesend, abwesend / tag = anwesend, abwesend
https://homey-cloud-id.connect.athom.com/api/manager/logic/webhook/anwesend?tag=anwesend
https://homey-cloud-id.connect.athom.com/api/manager/logic/webhook/abwesend?tag=abwesend
Where is my mistake
Unfortunately I don’t know what’s going on so I can’t help you, but I just wanted to say I have the same problem. Following @Rocodamelshekima’s suggestion (IOS Presence app (locative)) but for me the webhook flow never seems to be triggered.
Best use event=precense?tag=present
event=precense?tag=notpresent
Rest of the url looks ok
Flows in Homey will look like this:
Guess that was my mistake.
U can also try to make a flow in Homey to send te GET request by picking a logic card stating “Make a web request” . Just to double check
Well, you misspelled it both in the webhook and flow part, so it should work if the example was followed to the letter
True that
many thanks for your help…I have found the mistake …it was a problem with Node-RED
