Kostal solar panel
Can’t find any app for Kostal solar panel, is there someone in this community that have connected your Kostal solar system in Homey Pro -23?
Hello @PerJohansson75 , I am looking for the same thing.
I have a Kostal Plenticor Plus 8.5…
Did you find out something more?
/Guy
Hi @Guy_Werckx, no I havn’t found anything yet.
I have also Kostal Plenticore Plus 8.5
//Per
OK, i will try to find a developer who can help with this.
/Guy
Great @Guy_Werckx :smiley: Let me then now then you have succeded
hi guys, any success implementing plenticore?
I’ve installed Solar Panels and SolarEdge+ Growatt TCP modbus, but it dosn’t work, so I have to run my heater manually.
Hi there,
is there any other news on this?
BR
Andre
I have been looking to find a developper who can help creating an APP for Kostal Plenticore integration, but no positive feedback so far. I am wiilling to pay for the development, but nobody seems to be intrerested…
I have a older Kostal Piko 7.0
It would be great if this could be included as well
Maybe there is an integration posibility with the Kostal Solar Portal ? KOSTAL Solar Portal
Hi there,
Any news about that topic?
Description of the “SolarEdge + Growatt TCP modbus” App says, it’s compatible.
Did you already tested?
Hi, I don’t succeed with SolarEdge + Growatt TCP modbus” , need some help to get it working
I need a vendor supplier to add my mail account into SolarEdge portal as below, otherwise I want be able to login and add my Kostal environment.
  1. Ask your installer to register your email to your site.
  2. Once registered, you will receive a confirmation email with the link to the SolarEdge monitoring platform.
    If you have not yet received a confirmation email, please contact your installer.
I have now got it working with the app ‘SolarEdge + Growatt TCP modbus’ .
To do this, the Modbus must first be activated in the local Kostal interface:
  1. Enter the IP address of your inverter in the browser line (shown in the display of the inverter). You need to be in the same network as the inverter.
  2. Click on ‘Forgot password’ and create a password for yourself as the system operator using the ‘Master Key’ (left on the inverter nameplate)
  3. Once in the user interface, click on ‘Settings’ on the left and then on ‘Modbus / Sunspec (TCP)’. Activate the Modbus there and make a note of the port and ID.
  4. In the homey app ‘SolarEdge + Growatt TCP modbus’, go to the app settings and enter the IP address, port and ID there
It works perfectly for me now!
Great you got it working. Which model inverter do you have? I still have the Kostal Piko 7.0.
It’s a KOSTAL PLENTICORE - L-G3
