Hello
First, sorry if this question is in the wrong thread — I’m new to Homey and this site.
please advice where to put it
I have a KOSTAL inverter with a battery pack connected.
I would like the inverter to stop discharging the battery when I start my EV charger (Easee model).
I asked AI, and according to it this can be done with Modbus TCP by setting register 1034 to 0.
Has anyone made such a solution via Homey, and if so, would you share it?
Hello Bo, and welcome.
You can use the Solaredge + Growatt tcp Modbus app for Kostal.
Any questions go to the dedicated app topic, as mentioned on the app page at the homey.app store; and often howto’s and FAQ are present in the opening post:
Purpose
The difference of this app and the already existing solar panels app is that this app reads the data directly from the inverter.
The solaredge api and others are mostly limited to 300 calls/ day, so you get only updates every 10-15 minutes.
The modbus app receives data every few seconds.
If you have the Solaredge energy monitor installed you can maximize your self-consumption and limit your exported power by using it. You can make flows based on your generated solar power, exported p…
Forum guide:
Hi!
Welcome to our Forum, we’re glad you found us!
On this Forum you can discuss everything regarding Homey and Athom. This forum is for everyone, independent of your knowledge and experience with our products. I thought it would be a good idea to set some guidelines so we’re all getting the most out of this medium.
Here we go:
Please stay on-topic.
Please use a meaningful title for your thread.
Search for your topic ideas on the forum to see if somebody else already mentioned it som…
