I have a device on KNX that is giving me the Energy usage in KW or Watts.
I can see it in the ETS. But when I want to get it in Homey and choose for power than nothing happens.
It seems like homey does not read this sensor.
Has anyone luck with this ?
Klash
June 21, 2023, 6:46pm
2
@JanWynen i have the same issue, im investigating on this, and your topic Is old but i ask you if you manage this.
@Klash @JanWynen Same issue for me, is there a workaround?
Klash
July 14, 2023, 10:08am
4
Not yet from my side
I opened a case here Support | Homey
I think it could be a mismatch between data types. Iโm using Power(W) in ETS and the KNX plugin for Homey is probably expecting something else.
I have a workaround for this if you have a NAS, Raspberry Pi or anything else that can run Docker.
With the help of knx2mqtt you can communicate with KNX.
https://hub.docker.com/r/krambox/knx2mqtt/
On Homey I have been using MQTT Client, HTTP request flowcards(for parsing JSON), Better Logic and Virtual Devices.
Hi, Looks good, but a bit to difficult for me
Hope Homey can come up with a solution @Klash
