KNX App with Bab-Tec EIBport KNX/IP Gateway?
Is there anyone who has success using Homey KNX app with a Bab-Tec EIBport?
The KNX app detects the KNX/IP Gateway automatically.
Using Learn Mode I see devices being recognized by the Homey KNX app but sending any KNX message to the bus doesn’t work.
Any idea?
Does the Homey KNX app use Tunneling or Routing mode? Can i configure/enforce Tunneling somehow?
(I know that this configuration is working for another KNX-MQTT gateway:
ipAddr: '192.168.1.13'
ipPort: 3671
forceTunneling: true
physAddr: '2.1.11'
suppress_ack_ldatareq: true
Ciao,
gagga
@gagga
Just got my homey and have the same issue as you. Have you found any new information?
Brgds
/Fredde
No. Athom doesn’t seem to care. The support ticket is open since May with no resolution.
In the meantime I even got an offer from them to buy another KNX/IP Gateway (Weinzierl) with a discount. Ridiculous…
Any luck Solving this?
Yes. By adding a Weinzierl Gateway and moving my critical KNX stuff over to Home Assistant. I only kept the thermostats on Homey. The new version of Homey’s KNX app appears to be more stable but I can’t really tell as the traffic my thermostats generate is really low. So I wouldn’t notice any connection drops.
Hi There,
So I undertand taht the success of the connection depends on the model of the gateway ?
It’s not generic ?
I’ve just moved to an house with a full KNX infra and I’m totally newbee.
I’ve installed the KNX app 2 days ago and simply try to add a new KNX light.
the app asks me for the IP of the gateway.
I think the gateway installed is a MTN680329 - KNX - routeur KNX/IP | Schneider Electric
However, I’m not sure this what I’m supposed to ping
The scan function of the app doesn’t return any IP and entering 192.168.1.11 returns “There was an error”,…
IS the app reliable ?
Hi @gagga ,
Have you still issues with Weinzierl gateway and your KNX setup?
I have a similar issue with the Bab-Tec Appmodule ; Homey can see the status correctly (read the KNX bus via the IP gateway) and I do see that it sends something on the bus via the Bab-Tec module that seems legit, but somehow there is no actual response from the KNX device, so maybe data is a bit malformed by Homey/Bab-tec combination which causes this issue.
With HomeAssistant there is no issue reading and writing.
