Hi, i have a question.
I got a json feed from all the weather stations in NL.
And the radar gives an url back
https://api.buienradar.nl/image/1.0/RadarMapNL?w=500&h=512
But i cant get a text variable to become an image that i can use in other flow.
Does someone know a solution for this or is this not possible.
Old app but still works great thanks a lot!
RonnyW
August 24, 2022, 6:41pm
4
Hi, you could just use the virtual camara device. Add the camera (from Homey in the app selection) and insert the URL. Gif and Jpeg results can be used. So you can open this device to check the Image. And you can use the global image tag of that device to get the image (instantly updated) to use for push messages.
@RonnyW Can you maybe share a screenshot? I could not find it yesterday.
RonnyW
August 25, 2022, 8:05am
6
Add a device, select “Homey” and “Virtual camera”.
Enter your URL
Then you have a device and in device details, you will see the image
Ah thanks, i needed adjust my settings under “Experiments”.
To bad that the iOS app does not support a gif. But for flows and push this also workst great thanks!
RonnyW
August 25, 2022, 9:42am
8
Nice to hear. I can’t say what’s included in experiments because I activated it from the first day
Hey Maurits,
Coming up in DeviceCapabilities (not yet in test, bugfixing right now): A virutal device to which you can add 10 camera’s (plus much more).
