"It won't rain the next .. minutes"
My Velux windows are controlled by Homey. If it starts to rain, they close to 30%. If the rain stops, they restore to the position before it started to rain. Works flawlessly, but…
If the rain stops briefly and it starts again in a couple of minutes the windows keep opening and closing.
So, I would like to have a condition like “It won’t rain the next … minutes”, but am stuck in finding a solution.
Any ideas?
Thanks!
Perhaps use the Open Weather app.
And, it will always be a assumption :stuck_out_tongue:
try with Openweather - OpenWeather App for Homey | Homey - you can add hourly forecast, eg. forecast in next +4 hours - I’m using it as thunderstorm alert, eg. to disconnect some appliances…
Not sure it Arie means map itself, but probably a typo.
Btw, just small curiosity, I don’t know how Openweather is doing it BUT - my local rain sensor (updated each 6 min) is SLOWER then the actual weather state reported by Openweather :wink: I don’t get it.
Thanks for the suggestions, will give it a try!
You could disable the flow and enable it after xxx minutes. This way my lights in the livingroom respond to the lux, otherwise you get the same as your windows.
Unfortunately (…) it’s part of an Advanced Flow, so disabling it will result in other parts of that flow also not being active.
In that case you can use a True/False variable
I made four advanced flows, first flow with the conditions, second flow light on, third flow lights off and firth flow with the disable and enable conditions. In my case i disable the second flow and enable it after 15 minutes
I would suggest a cool down period with a timer instead of disabling a flow.
Tried Openweather App, but couldn’t get it to work (even after entering my payment details).
I found the App Buienalarm that does what I need: it has trigger and condition cards that I can use in my flows.
Thanks for all the input!
