Issues with Aqara FP300
Perhaps Aqara should consider stopping their predictable practice of gatekeeping entities
Thanks… really helpfull and constructive :face_with_peeking_eye:
Well, Aqara should know that they will continue to receive many thousands more customer service and technical tickets about the sorts of issues we see on this thread.
Of course, the reason they’ll continue operating in this way, is because their current business model ensures high turnover through releasing the same products over and over, every year; rather than just fixing firmware issues and stop gatekeeping features that the devices are perfectly possible of providing.
New app update has been release with improved communication (active check after 15 minutes if presence is still active), including the firmware update option to update the FP300’s to the latest version.
Current test at the latest FW version, with capturing the RAW zigbee communication as well as comparing the actual hub logs, between a set of FP300’s paired to Homey and a Aqara M3 hub, did not show any differences in cancellation behavior.
Following up on the previous discussion, I would like to report the following regarding the Aqara FP300 Presence Multi-Sensor.
The day before yesterday, I reinstalled an Aqara FP300 for the second time. After approximately 30 hours following the initial installation, Homey Pro Early 2023 (firmware V13.1.n), in combination with the Aqara app V1.19.n, appeared to stop receiving sensor updates. Upon checking, I discovered that the last updates had actually been received 13 hours earlier.
For the initial setup, I first paired the FP300 with the Aqara M3 Hub using the Aqara app and switched it to Zigbee mode. I then removed the FP300 from the Aqara app/hub and paired it directly with Homey Pro 2023 (firmware V13.1.5.3), using the Homey Aqara app V1.20.0.
After approximately 24 hours, updates from the sensors [Humidity], [Lux] and [Illuminance] stopped. Even after another 17 hours, these sensors still had not reported any new values according to Homey.
To summarise: Compared with the previous installation using Homey Pro 2023 V13.1.n and Aqara app V1.19.n, where all sensor updates stopped after approximately 24 hours, the current setup with Homey Pro 2023 V13.1.5.3 and Aqara app V1.20.n still receives updates from two sensors: [Presence] and [Motion].
(An additional observation while writing this post:
The lights suddenly switch off, and I notice that both the [Motion] and [Presence] tiles of the FP300 in the Homey app turn grey. After approximately three seconds, both tiles turn red again, and the lights switch back on. The Homey Pro and the FP300 are located just over 2 metres apart.)
I also have another FP300 connected to Homey Pro 2023 via Matter, using the Aqara app V6.4.4. This sensor works as expected.I can see this FP300 in the [Accessories] dashboard of the Aqara V6.4.4 app, as well as in Homey.
However, the [Presence Activated] and [Presence Deactivated] tiles are missing and therefore cannot be used as Flow triggers.
My assumption is that, when using Matter, [Presence] and [Motion] are represented together as a single status in Homey: When I enter that room, the lights switch on. As long as I remain in that room, the lights stay on continuously. Once I have left that room for more than 10 seconds, the lights switch off.
Indeed, that is a Matter limitation (as with a lot of different manufacturers, they offer a subset of features via Matter to all ecosystems, and all features via Zigbee and try to sell you their hub).
I have been trying both Matter and Zigbee with the FP300’s, and I’m also considering trying one connected to HA via ZHA and a Sonoff Zigbee 3 dongle, then Matter bridge it to Homey, and see how that behaves. So far having it connected Matter over Thread seems more stable.
I really want to love the FP300’s, as I do most of the Aqara kit I have… but these sensor lock-ups are really driving me nuts.
I have one Lafaer LWR02 that connects Matter over Thread to my Homey Pro… it hasn’t skipped a beat. 2 months now in my bathroom, and it just works every time I walk in. And all my other Aqara hardware, be it Zigbee or Matter over Thread has been dead reliable, and just works. It’s just the FP300’s, and there doesn’t seem to be any discernible pattern, rhyme or reason to it. Out of 10 FP300’s everyday a random one (occasionally 2) will go on the fritz and need a Repair running. But it is rarely the same ones… which room will it be tomorrow :man_shrugging:
Most frustrating.
I have exactly the same issue. Used to affect two of my six FP300s, but one seems to have “fixed itself” (may be due to me moving around a zigbee router). Also had the same issue with two of five W600 (stops reporting valve position, temp gets out of sync in Homey compared to on-valve after 24h), one seems to have fixed itself there also.
Well it happened again but with different windows: About an hour or so after I posted my message, the lights switched off again, and the [Motion] and [Presence] tiles turned grey. After about 20 seconds, the tiles turned red again and the lights switched back on.
About an hour and a half later, it happened again, but this time the delay was much longer, several minutes even. No matter how much I moved around, the sensor didn’t detect anything. Only after those few minutes had passed did the tiles turn red again and the lights switched back on.
It happened again later that evening, so I removed the FP300 from Homey, took out the batteries, put them back in, and then paired the FP300 with Homey again.
THe FP300 is running fine now. Let’s see how long it behaves itself this time.
Well t.b.h. I’m starting to lose my faith in the smarthome industry Hue excluded. Although I find Hue far too expensive but it has failed me only once after a major update and I have Hue for (>7?) years. Hue was my first platform, then I added Amazon Alexa, Hubitat, Homey Pro early 2023 (with bridge), Homekit (Apple HomePod Mini) and finally Aqara M3 Hub. I don’t use Apple Homekit yet and I don’t use Hubitat anymore. The industry promised that the devices would be able to communicate cross paltforms. Well, we’ve arrived and it brings only a lot of frustration.
I also bought a Aqara W600 yesterday to see whether Aqara is a better enough brand for my Homey then Netatmo, but the prospects are not good as I understand now.
Anyway…..we’ll see
Okay, a good 24 hours have passed. The [Temperature], [Humidity], and [Illuminance] sensors of the FP300 are no longer updating.
The updates did not all stop at the same time. I have listed them in the order in which they first stopped working. The time intervals between the individual updates stopping are approximately one hour.
Yesterday, when pairing the FP300 with Homey, I configured the LED to turn on. And indeed, the LED responded to changes in the FP300 settings, including during the day today. However, it no longer responds to changes in the settings either.
I have given up on my FP300’s. I am slowly replacing them with Lafaer LWR02. They simply work
I have come to a similar conclusion… though it’ll take me a while to replace all my FP300’s, but the LWR02 has been rock solid reliable.
The same here. I am doing two per month. But what is odd that about 5 of my FP300’s are rock solid connected to thread. The rest are constantly offline
I’ve heard the LWR02 aren’t great when sitting still for very long periods
@deejayreissue that has not been my experience. In fact the exact opposite. The FP300 I used to have in my en suite worked fine when I was constantly moving and stood up in the shower… but pretty much every single morning when I went for my morning download I’d end up sat on the throne doing the funky chicken like a demented person to try get the light back on in the tiny little windowless box that is my en suite.
Since I changed it out for the LWR02, an entire month of not having to do the funky chicken every morning, most thankfully!
The whole point of mmWave radar sensors is they are meant to be able to pick up the slightest movement, like breathing… but an FP300 only 1.5-2 meters away in a tiny room with no interference sources and it’d lose sight of me sat relatively still-ish.
I love most of Aqara’s tech (and I have quite a lot of different devices) but the FP300’s have been the absolute bane of my existence for the last year. So far (not wishing to jinx it) the Lafaer LWR02 has been faultless for just over a month. So much so, I am considering replacing all 10 of my FP300’s, when I can afford to, if these problems can’t be rectified with the FP300’s.
And I am giving them the best possible chance, by removing them from my Homey and adding them to an Aqara hub one at a time to update their firmware, and hopefully be able to just run a repair to add them back to Homey without having to recreate all my Advanced Flows. The Aqara app does label this firmware update as an “Important Version”, and lists improvements to most of the things that have been irking me about them. I did try many many maaaaaany times to do the OTA updates through Homey. A grand total of one updated after quite a few attempts, but every attempt since on the rest of them has failed.
Maybe it’s just me, but if I spend the amount of money, time and effort that I have on these FP300’s, I expect them to work, and consistently, not when they feel like it.
EDIT: my first trial of adopting an FP300 to an Aqara hub to update it’s firmware, and then run a repair on Homey to re-add it back to Homey updated has worked. I’ll see how it runs over the next few days, and if I notice a big improvement I’ll report back, and start one by one updating all my others :crossed_fingers::crossed_fingers:
Have an FP300 in both bathroom and downstairs toilet on HA over Thread, then into Homey using the main HA app
Zero issues
Homey’s pants Thread antenna is the problem, as it usually is
